I would have no issues running a pulley 5-8mm past the end of the motor shaft. There doesn't need to be much side load - the teeth on the belt help us out a lot. I agree a second bearing would be nice, but I kinda doubt it's necessary. The biggest advantage we have over the RC guys is that we're only running our motors for literally seconds at a time. Thanks for this pulley info! I need to step out for a bit, but I'll poke around online later and see what I can find.
Frankly, I'm rather excited about this particular setup. This opens the door for so many people who don't have access to machining stuff. If you do it carefully, all you'd need is a skill saw, a drill press and a file. Heck, I built two blower setups in the 90's and early 00's without much more than that. The only welder I had was a HORRIBLE Harbor Freight flux core. I spent a lot of time grinding ugly welds.
hah ... eureka: or we could use a "hollow" input cog/pulley with the cavity facing downwards and mounted "high up" the motor shaft.
The cavity would have a portruding motor shaft and space for a 2nd bearing and a elevated bearing seat...
