What temp was that last test at?
Hey guys I found this A123 32157. I talk with Alex and he found a good deal on ebay of cheap A123 26650 with good specs and I want to go with it for a good moment now. The specs of the 26650 is about 70A continuous Discharge and 120A in pulse.. I want to have a set up of probably 15s5p so 48v with 350A. The problem is the 75cells that I need to spot weld with copper/nickel strip but im not a big fan of it.. and I found this! Little bit biger in diameter and little bit more then 2x longer BUT a lot more power 210A continuous its going to be pretty much the same battery size but lot less cells and the cells going to be screw and not spot weld !
Wath do you think?
View attachment 309View attachment 310
How the pouches look? Do you recommend it?I looked at them too, but after some research I declined from buying cylindrical A123 cells! (after the first purchase order actually had to be refunded due to fake shipping)
Their new mother company (who bought A123) stopped producing any cylindrical cells in 2017! (only prismatic pouches are being produced)
So all those cheap A123 cylindrical cells are not brand new. Best case 5 years shelf time, worst case "recycled/refurbished"!!!
I don't think I would recommend the seller I got them from; and they're out of stock. A bunch I ordered showed up dead and they weren't new as promised (some have different length studs, etc). Most of them have come back after charging and testing them all (literally been doing that for months when my bench power supply is free); but they did give me a bit of discount. Even with the discount, I still paid well over $1,000 for them all. Just buying 24 cells would still set you back about $400-$600 if you can find them. I would use the batteries SQCTS on here found. They're smaller, easier to work with, cheaper and have really low internal resistance.Where did you get your LTO cells from and what kind of price range they were for each? I have looked at the compressor maps and made a gear drive with 1:2 ratio. Yet to test it out, eCharging seems kinda interesting option.
I will go with them too! Look good and I have a nice Idea to clamp them! I will machine some custom copper clamp with some custom insulated holder for them! 15s is about 48v 20ah compare to my last set up of 12s2p LTO of 5.9ah.looks and first IR test (single cell! but I am shooting for 16s4p => 16x(0.125mOhm) overall):
Post in thread 'What batteries are you using?' https://www.electrifiedboost.com/threads/what-batteries-are-you-using.8/post-1082
do I recommend them? can't say yet ... battery case and clamping mechnism is "in the make" ... then they need to prove themselves under real load. Are they good? According to my research (see my post hereost in thread 'What batteries are you using?' https://www.electrifiedboost.com/threads/what-batteries-are-you-using.8/post-1058 ) they should be! In the past some Porsche concept car used them as well
