TBrick - Through the restrictor?  I don't know.  To be honest, that's kind of a BS number anyway.  It doesn't reflect the dynamic conditions it would see on the engine.  That's why I didn't bother to hook up a boost gauge last time.  It was taking people off topic (judging by the comments).  I can tell you I expect to see about 8 psi or so at peak hp and about 10 psi peak off the trans brake.  Give or take a couple of psi.
cmoalem - It's not just the direct drive that makes it smooth.  The two poles help quite a bit as well.  Seems the fewer poles you run, the less "magnetic cogging" you see.  It's true the belt drive option does add a little noise, but I really think it's more from the motor itself.  As for what more can I add - well, I've been already been thinking on that.  We've tested both extremes - high RPM and high load (i.e. power).  Voltage drop, as always, is our enemy (at least once stuff stops blowing up).  Oddly, the long cables are only responsible for about 2 volts of that; the rest is batteries.  I have more than enough Lishen cells to add another set of packs in parallel.  That would, in theory, cut the voltage drop in half.  So that would be the obvious thing to do.
Let's do some bench racing: in the tests in the video, the packs were charged to 61 volts; at 678 amps (that was the peak, but average was still 650), the pack voltage dropped from 61 to 48 volts, giving us 9 volts of pack drop (remember 2 volts from the cables - it's really a hair over 2 volts at 678, but close enough).  The caps in the ESC are 63 volt caps - that would be the obvious limit there.  So let's say we can safely charge the packs up to 62.5 volts; but let's call it 62.  In the car, let's say the e-turbo will draw 550 amps; so pack drop (more or less linear) should be about 7.5 volts.  By adding an additional volt by charging higher and 1.5 volts with less current draw, we'd be at 50.5 volts under load.  KV isn't constant - under the max load in my tests, we were at about 585 KV.  in the light load (i.e.restrictor) tests, KV was about 705.  A safe bet for KV under the 550 amp load is 640.  So we can expect 32,320 impeller rpm.  that's almost 10,000 rpm less than I was hoping for.  If we add a second set of packs, we should pick up another 3.5 volts, for 54 in total.  That would still only get us up to about 34,560 rpm.  BUT - and this is a big one - with the APD/TP Power setup, we only saw 26,000 impeller rpm and got 4 psi of boost.  If we only see 32,320 rpm, we're only going to pick up a pound of boost at peak hp.  But that's not the way it works with this setup for some reason.  According to the Vortech Si compressor map, at 4 psi and 26,000 impeller rpm, we should've only made 600 hp.  But we made more - 50 hp more, going by BSFC.  That additional 50 hp likely comes from the fact that I'm not running the Vortech cast impeller, but a billet impeller - which gives a 5mm larger exducer diameter, is considerably lighter and has a much narrower center section for more flow.  The compressor map tells us we should see 720 hp.  But add in the additional 50 hp for the billet impeller, and you're at 775 hp.  And just because I think it'll do a little better (I mean, c'mon - it's going to be right at double the power of the previous setup - right around 28 kW), give me 800 flywheel.  Throw some oxygenate in the tank, and there's your 850.  Oh, and it should be a little over 6.5 psi at peak hp and 8.5 at peak torque.
See - isn't bench racing fun?  I just gave myself 75 hp more than the graph tells us it'll make!  Lol.  But the billet impeller gains are real.  Actually, going through these numbers is helpful to me to zero in on what to reasonably expect.  Assuming everything holds together on the dyno, I won't be happy until I'm over 600 rwhp through the glide.  It'll take 800 flywheel hp to get there.
BTW - This is the kind of stuff that keeps me awake at night.  Just not knowing what reality brings over theory...
This post got a bit out of hand.  Sorry.
