SGL12GUNNER
Member
There is a guy on V8 miatas FB group that seems to know about programing. He is working on traction control. Our cars are grip limited in the sense that the largest time we can run is a 275 which requires some work to do. At my current power level (376whp) with some old 225-15 NT01's I still loose traction on the 2-3rd shift. I will be putting some 245-15 RT660's on and going down to either a 3:15 or a 3:08 rear ratio.
If your car already has abs it's easy to add a sensors front and rear I needed to add a sensor for the GM PCM on my build. It would be easy to add one to the other side of the front of the car.
Hell for you (if you don't have abs) you do have a lathe, you could press fit a tone ring somewhere on the front possibly?
I will see if he is interested in chatting with you.
