| This shaft  | Next Shaft  | |
| Chucked up deep / full length of jaws | Chuck up shallow.. maybe 1/2” max | |
| Longer piece than needed | Go back to minimum length | |
| Cranked down hard on chuck key | Reasonable force. Perhaps using copper foil at jaws | |
| Low grade hot rolled steel (for practice until new stock arrives) | 1018 steel | |
| Wonky wobbly piece of stock difficult to chuck properly | Start with round stock or skim coat it before chucking | |
| 5/8” stock | 1/2” stock to minimize material removed / heat | |
| Tight live center (that got tighter with heat) | just enough tension for live center to spin | |
| Deep, heavy cuts | Shallower cuts to minimize heat | |
 | Rough in to 0.020” over then let cool before finish passes |
Good thing I am learning driven!This is how you learn unfortunately. It can be painful at times but it is worth it.
This will be the same when writing code!
 so you could direct drive your compressor wheel without extension shaft!
 so you could direct drive your compressor wheel without extension shaft!My guess is either 1) was bad from the start or 2) there was axial thrust from the compressor and the rotating assembly stopped fast when the compressor contacted the turbo housing. I cant really recall as it was a while ago and did not seem catastrophic at the time but rather a metallic squeal and it was stopped immediately.Do you know how could this happen?
Great minds think alike! That is precisely what I have been pondering. Somehow removing the steel shaft from the magnet portion and making my own shaft with no extension.If you are ever left with a rotor on the shelf, you can try to make your own motor shaftso you could direct drive your compressor wheel without extension shaft!
I did try with my TP motor and it was glued and pressed. They scuffed the surface of the shaft so the glue can stick. I did pull the shaft out with a press.My hunch is that the easy way to get the shaft out would be heat. But I would be concerned about the heat demagnetizing the neodymium magnets I may just have to try pressure, but my hunch is that may shatter the magnet array.
Remember the bore with an endmill tips I gave youNow I just need to figure out how to make a hole that size in a new extension shaft to receive it.
I do like that tip and actually leave a 1/4" end mill in one of my lathe tool holders. I think I still struggle with the dimensions as I can't seem to get a good inside diameter measurement on small holes. And once I do I am relying on lathe micrometers, which aren't bad. Maybe I just need to set up a dial indicator to measure cross slide position. Or, maybe I just need to bite the bullet and get a DRO kit for my lathe.Remember the bore with an endmill tips I gave you
