Hi All,
WB Projects has been talking with me about his project through PMs. Since this is a "let's all learn together" type of forum, I asked him if I could move our conversation to a thread here.
I'll start by going be to a point in our PMs that makes sense.
WB Projects:
Good new for me I've made a new set up with the intake and the maf sensor and now it work like it suppose to! The turbo still surge on low rpm.. the tunning will be this week
AlexLTDLX:
That's great to hear. If the turbo's surging at low rpm, then maybe your engine isn't flowing enough at air that point? If it was me, I'd start the turbo above your torque peak at first (peak torque is peak cylinder pressure, and it can be tricky to tune things there; you have more leeway at high rpm). Once you get high rpm flow/boost worked out, then work your way down, rpm-wise. With all my screwing around with positive displacement superchargers, I've learned that lesson the hard way. Several times in the form of destroyed pistons.
It would be easy to modify the arduino code to ramp in boost with rpm; you could use maybe a tach output, or maybe even tap into a crank (or cam speed sensor) - or, possibly easiest still; use a cherry hall-effect sensor running off your balancer bolt bosses or something. When I first put the Megasquirt in my car, I couldn't get the magnetic sensor in the distributor to work reliably; especially under boost. What I'm using now is a cherry sensor getting triggered by the 4 bolt bosses on the harmonic balancer - that's literally what triggers my EFI setup:
And here's the mount in the car:
WB Projects:
Programming the Arduino is an excellent idea! If I understand, the cherry sensor count the rpm and send a signal. With this signal I can tell the Arduino to be 0-100% depending of the rpm! I will check exactly how work the cherry sensor. Is it a magnet inside ?
Correct me if im wrong. I bought a bigger turbo because for the ones I search for, the efficiency was way to high in RPM for the TP motor I have. So the bigger one have my goal way down in the compressor map. Maybe this is where my surge problem is! Too much flow and not enough compress? Do you think that's possible?
I want to turn the ESC up for more boost but the compressor surge.. so I try to figure how Im I stuck at 3psi before surge
AlexLTDLX:
Yeah, the sensor is a hall effect type and detects when anything metal passes in front of it. And you have the surge concept a bit backwards - what you're describing is choke - the right hand side of the map (too much flow and not enough to compress). Surge happens when there's not enough flow, and the air is forced to go back through the compressor - that's literally what causes the surging - the air pushes back through the compressor (and loads it further) and then when enough air goes back through the compressor to relieve enough pressure from the discharge side, the compressor can then speed up until it happens again. It's a cycle that repeats and we call it "surge."
To get rid of the surge for now, just start your turbo later in the RPM band. Do you have a compressor map for your turbo? We can look at it and see exactly what's going on. Can you tell from the ESC how fast it's spinning?
I'm thinking of maybe moving some of this conversation to a public forum post - I think there's a lot of good info here, and you're the only other person that actually has a working unit. Would you mind if I did that?
WB Projects:
For sure we can discuss public! For now Im at work and the wheel of idea keep spinning in my head.. I will make a first tune, then tune the ESC with the help of MGM then after we will see wath really happen.. but for what I can feel is when im at low rpm and I activate the supercharger, I hear a surge noise and the gauge boost go up and down like crazy. When I try on the bench, put my hand in front and start the turbo, I hear the same noise and I feel no pressure on my hand. I feel some flow of air on the intake and the exhaust of the compressor housing, but no pressure. I can block it super easy from 0 power but when I start the supercharger, then try to put my and in front to block it is way more difficult..
For the compressor map is a chinese GT35 so the compressor map is a supposition from the real deal
WB Projects:
Good new for me
AlexLTDLX:
WB Projects:
AlexLTDLX:
WB Projects:
		 you and mkgnstuff should have your name on the e-turbo for the help you gave me!
 you and mkgnstuff should have your name on the e-turbo for the help you gave me!  so maybe it going to be only next summer that I will do some other test. I want to make it work nicely this year and improve next year!
