MkngStffAwesome
Active member
I see they are now making a TP4080-CM which is great news... well for some of us :0
https://www.aliexpress.com/item/1005003765826702.html?spm=a2g0s.8937460.0.0.23372e0e1olWr6
- Motor mod.: TP4080-CM
- Max. power: 11.000W
- Cont. power: 6.000W
- Max. RPM: 68.000
- RPM per volt: 2022KV and 2700KV
- Max. volt (LiPo): 2022KV (8S), 2700KV (6S)
- Max. amp: 2022KV (324A), 2700KV (426A)
- Pole number: 4poles
- Shaft diameter: 8mm
- Mounting: M4 (4mm)
- Flat spot no shaft: yes (or without when requsted)
- Output shaft lenght: 24mm
- Diameter*Lenght: 40*117mm
- Weight (aproxx): 720g
