MkngStffAwesome
Active member
People can do what they want.. in this topic you can run oil or no oil...Don't want to create drama but you "poo poo" my charging set up with the BMS and I did it anyway and it work fine.
Sometime I don't like the way other solve their shaft to impeller problem in the perspective of a machiniste, but at the end, you make your set up and if it work, it work!
He's trying to give you infos and datas, he's not saying that is a super bad idea
I can't remember the bms discussion ..
But i think from memory you were charging through the BMS but not discharging through the BMS.. which means you have no protection for under voltage.
People can run with a BMS or not .. People can run with or without a active balancer..
All will "Work"... The only discussion is how reliable will it all be in the long run and if that even matters.
