I read up on BLDC phase current and agree that it's not possible to get power to the compressor from the phase current.  So it would be interesting to know the battery current.
The P2 compressor curve is fairly flat and doesn't fall off until you get to higher flow rates. Below is the data for discharge pressure at 30,000 impeller rpm. On a small engine like a 2.8L, the manifold pressure is going to be essentially constant at any engine rpm. The mass flow of air into the engine (which highly correlates to HP) will depend on the manifold intake, the air temperature, engine rpms and the engine's volumetric efficiency. On fuel injected engines that use speed-density for fuel control, volumetric efficiency data is available by reading the EPROM. If the engine does not flow at least 1080 lbs/hr, the P2 will surge (and make some real noise). Because the curve is flat at lower flows, you can't tell if you are getting near surge from the manifold pressure.
If I know the orifice diameter, orifice thickness, pipe diameter, and discharge pressure, I think I can calculate the flow within 10%.
| lbs/hr | psig |
| 1200 | 6.3 |
| 1800 | 6.7 |
| 2400 | 6.7 |
| 3000 | 6.5 |
| 3600 | 6.2 |
| 4200 | 5.1 |
| 4560 | 3.6 |
