WB projects
Active member
Go with LMT motor or TP power. Depending on the budget but you will get what you paid for with LMT. Shoot for the motor power then look the RPM.
			Technically 48v is always better than 12v and 60v is always better than 48 and 400V is always better than 60v... The reason why you might chose a lower voltage would be ESC limitations ...(cost)Can you recommend 12v to 48 or 60, step up converter. My alter story puts out 100amp most of the ones I see are rated at 20a
Is it ok to step up the 12v system to 48 or 60 or do i need to start with the higher voltage battery then step up after the alternator to charge it.
I'm thinking something like this could be a good start.
It look like you try to go backward of what you need. Set you a goal, find your motor and turbo or procharger at the same time to match, find your ESC to go with the motor, then look for the batterys. Do you need more or less voltage depending of your power and current limits. Now you can look at your charging set up.
For the motor, its simple keep in mind that they are all arround 50k rpm. LMT or TP power
If you want a lot of boost you will probably need a high torq motor so maybe you should look with LMT
For the ESC, user friendly, there's MGM controllers. APD have been tryed and fried. So maybe not for now with APD
Now you know that you can run your motor arround 50k rpm. Do you need to gearing up? So find a compressor that is viably clost to your goal.
For the part of assembling everything, we can't suggest you something because they are all work in progress! So try to see all of our idea and try something new or follow our path.
After that, you can worry about your battery and charging method. You are limited by RPM and not by the battery and charging methode
That battery obviously can't power your system,... well not one of them anyway
Hello, new here.. I have been reading a bunch, and I'm a brand new to brushless motors.
I see Alex had a step up, and is now stepping down his set up. I am curious as to how stepping down is going to help.
I understand the motor needs load. I don't see any one here that has stepped up to a ratio of at least 3.0:1.
The issue I see here is you are trying to spin your brushless to max RPM.
RPM and torque are inversely proportional; as one increases, the other one must decrease. So if your step up is so close to 1:1 such as 1.22:1 you aren't putting any more Tq into the impeller at max RPM. So the only thing to do is to go with a larger motor to supply more Tq at max rpm.
I am most likely wrong but it seems to me we should be calculating the most efficient motor and gear for the desired impeller speed. EXAMPLE (Kv × V) / G1/G2 = RPM
(Kv × 48) / (54/18) = 40,000
Kv = RPM x (G1/G2) / V
40,000x3/48 = 2500 Kv
With that knowledge, you are using a larger motor with higher system voltage instead of gearing to get the the supercharger to spin faster
I know I'm missing some other concepts regarding motor load. But I I really think we are missing out on what potential we can achieve by selecting the right motor AND gearing.
One other thing that intrigues me is: The more boost you produce the more load on the motor?
I think we need a "larger" motor, with sufficient system voltage (but not excessive)...and appropriate gearing.
The P2 is nice as it already has a drive with 18 teeth... however... finding a pulley of greater than or around 54 teeth and a belt that will be a slight challenge... but maybe not as challenging as finding a motor that will do the job too... I wish I had more info on the LMT TorQstar3.
@AlexLTDLX I wish I had the means to test my self. But alas I can't. I know you tried the snorklet to simulate load. Perhaps you make a "boost tube" to allow a greater volume to be filled. Have the tube be roughly 2-3 feet long with that 90 off the blower, with the restrictor plate in the end of the tube.
Idk I'm spitballing here. I'm really hoping I'm correct in my thinking. As more boost builds the greater the load on the motor, resulting in being in the motors efficiency range...
School me!
 www.electrifiedboost.com
				I get that, but that is specific to the P2... I'm talking about gearing in general and was referencing his p2 build. Im talking about determining the proper motor and gear ratio for a a desired boost level/compressor RPM.i asked that in the other thread that i think is more appropriate
"why is he now reducing the gearing"
P2 Supercharger Thread
i expect the MGM to just work too.. DID APD replace your ESC's or is that just money thrown awaywww.electrifiedboost.com
 ... but the jury is still out for me weather this motor would benefit from gearing, or is this motor  still best suited for direct drive.
 ... but the jury is still out for me weather this motor would benefit from gearing, or is this motor  still best suited for direct drive. It is hard to wrap your head around things when you have nothing in front of you...
The math I provided above is what KV a motor would need to spin the compressor shaft to 40k rpm with a gear ratio of 3:1 @ 48 volts, which was about 2500kv. However this takes nothing else in to consideration. Such as load, in the form of the resistance the compressor faces as it moves more air. Let alone losses from the gearing/belt, Bearings
In a traditional supercharger you have your crank pulley which is rather large and a smaller pulley on the supercharger. That is where we get things mixed up. As the engine is high hp/tq but relatively low Rpm. But we are dealing with low hp and low Tq - High RPM electric motors that make their TQ instantly and as RPM increases the motors Tq decreases.
But look around in the real world applications. Now I don't know why I didn't think of this earlier, but if you look at Tesla and their drive unit, they are geared down not onec but twice. To the tune of around 9:1 depending on which revision you look at.
Take a look at any older AHU for a building HVAC system and those are also geared down. The pulley on the fan is larger than the pulley on the motor.
Now by gearing down you are limiting the final drive rpm. But your allowing more work to be put into moving the air.
By gearing up you maximize rpm to be put into the impeller shaft but it seems that the power isn't there. I don't think the TP power motor is good for anything other than direct drive. If we had a low rpm (relatively speaking) high tq and Hp motor then gearing up would likely work. Far better. But we don't have that.
The largest motor we have (to my knowledge) is the LMT 30100... which does have some power! Also has a really high price point...... but the jury is still out for me weather this motor would benefit from gearing, or is this motor still best suited for direct drive.
Given the price of that unit, unless you could get 9psi out of the P2 on the v8, it just plain costs too much to e-charge. But that is for another topic...
