Author: Michael Dixon Auckland New Zealand ( Ultrasonic2 from Making Stuff Awesome ). All rights reserved.
USE AT YOUR OWN RISK. I have no ability to know how this will work in all possible use cases or if it works in any cases at all.
It is Probal that there will be some unknown bugs with this.
This is intended for a Arduino 328P (5v) Nano and assumes yuor car is also 5V
Please consider becoming a Patreon @ https:www.patreon.com/Ultrasonic2
Known Issues:-
Nothing known.
If you have any issues please send me a copy of your debug with "EnableLog" set to 1
Testing:-
Only bench testing.
Getting Engine RPM has not bee tested as i'd need to connect it to a real car for that, which has not been done yet.
Below are a number of methods of controlling your E-Turbos Max Speed
1 Simple on off switch
2 Adjusting a Potentiometer (POT) AKA a "KNOB"
3 Via the cars Pedal Pressure
4 Via Engine RPM ( This Overrides 2 )
Soft Start to no overload your electrical system.
2-4 and be mix and matched. (The most restrictive one is the actual speed )
SO you can have just a simple Switch "1" OR a switch "1" and engine RPM (4) Or you could have 1,3,4
We then have 4 Out puts which can be used to control various external devices and a saftey feature.
++++++++++++++ DEBUG ++++++++++++++
debug mode ( out put everything over serial )
int EnableLog = 2; 0=debug disabled 1= enabled. 2= enabled only variables. 3= engine rpm only.DO NOT leave this enabled as it massively slows down the Arduino making rev up/down and engine RPM jerky. !!!!!!!!!
int DebugSpeed = 500; 500 1/2 second update speeds.
To read the output you'll need to use an App like "Putty" and connect to it on 115200 baud.
++++++++++++++ SWITCH ++++++++++++++
(Always Used / Required)
This is a simple switch that can be used to Start your E-Turbo . If this is the only option enabled then Max motor speed is defined by "SetMaxSpeed" See below.
If other options are enabled then this becomes an overriding On-Off switch
Trigger_PIN
++++++++++++++ KNOB ++++++++++++++
Use a Knob (Pot) to adjust max motor speed. Even with Knob disabled "SetMaxSpeed" is used to limit max motor speed!
bool UseKnobForMaxRpm = 0; 0= Pot disabled use FIXED max speed specified below. 1 = Use pot to very max RPM from 0 to Specified below
int SetMaxSpeed = 1000; 1000= 100.0% , 986 = 98.6%
int SetMaMinKnobSpeed = 500; = 50.0% knob goes from 50% to "SetMaxSpeed". Can be changed to go from 0 to 100% it's from 50% because 0=100 can be to sensitive.
++++++++++++++ SOFT START ++++++++++++++
(Always used)
Slow down the motors spinup to reduce spinup current and destroying ESC's
int SoftSartTime = 1000; ( time to slowly increase the ESC from 0 to 100%. 1000 = 1second)to "SetMaxSpeed". Max setting 30,000
float RevDownTime = 6000; 6000 = 6 seconds. Once you have decided the "Max motor speed" rev the motor and e-turbo to that and then time how long it takes to come to a complete stop.
This is used to estimate motor speed and therefore how much of "SoftSartTime" to reapply between toggling the switch or getting off and on the gas (for gear changes)
int IdleSpeed = 200; 200 = 20.0% min Idle Speed with battery flat FROM a complete stop. YOU'LL need to test this to find out what this is by setting "SetMaxSpeed" to a low number. See Debug
++++++++++++++ PEDAL LIMITING ++++++++++++++
Use the cars pedal
bool UsePedal = 0; 0= disabled h 1= use 5v from Pedal (car).
int UseMultiProfiles = 0; 0=No (first profile used), 1 = Yes Pin connected to ECU. 2= Yes with Pullup ( for external switch )
Values are pulled from the pedal sensor ( see debug to know what to change them too "**CurrenCurrentPedal"). The below numbers are just made up.
3 point pedal to rpm rev up.
0 to StartIdlePressure. No motor speed
StartIdlePressure to StartRevUpPressure. Motor is Fixt to "IdleSpeed". This done for 3 reasons. At this point it's not expected that any boost will be created.
1 This is just meant to spin the motor slow enought as to NOT create a restriction.
2 Getting Motor sync is actually a un known time and this therefore affects the Actual motor spin up time.. This is therefore a unknown additional time to "SoftSartTime " idling the motor prior thus removes this randomness, which can cause inconsistent Current pulled when spinning up.
3 Starting a motor from "0%" and slowly adding power can cause motor screeching and erratic behavior at low speeds. This avoids this by YOU ensuring a "IdleSpeed" is set to a speed that the motor can at least Idle at when your Battery is flat FROM A STOP.
Below StartIdlePressure 0% speed
int StartIdlePressureA = 500; Fixed IdleSpeed to StartRevUpPressure point
int StartRevUpPressureA = 700; IdleSpeed Raming to SetMaxSpeed
int FinishRevUpPressureA = 1000; SetMaxSpeed
Above FinishRevUpPressure speed = SetMaxSpeed
Profile 2 enabled by switch/ clutch switch. Intended for no engine load condition but could also be used as a difference config for different situations.
int StartIdlePressureB = 200;
int StartRevUpPressureB = 250;
int FinishRevUpPressureB = 300;
++++++++++++++ RPM LIMITING ++++++++++++++
This Overides "KNOB" settings
Used to specify different RPM's and motor speeds at those points
bool EnableRPMLimiting = 1; 0= disable rpm limiting. 1= enable rpm based limiting
int PulsesPerRPM = 6; 10 is max. The number of on or offs per rotation.. (this is assumed that you're connected to the engines CAM sensor. if your rpm is to high or low try changing this.
engine rpm can be massively thrown out by DEBUGing being enabled.
below RPM1 motorspeed is 0
int RPM1A = 2000;
int RPM2A = 2500;
int RPM3A = 3500;
int RPM4A = 4500;
int RPM5A = 5500;
Above RPM5 motorspeed is = to RPM5speed
int RPM1speedA = 200;
int RPM2speedA = 250;
int RPM3speedA = 700; 700 = 70.0%
int RPM4speedA = 900;
int RPM5speedA = 950;
int RPM1B = 2000;
int RPM2B = 2500;
int RPM3B = 3500;
int RPM4B = 4500;
int RPM5B = 5500;
int RPM1speedB = 0;
int RPM2speedB = 200;
int RPM3speedB = 700; 700 = 70.0%
int RPM4speedB = 900;
int RPM5speedB = 950;
++++++++++++++ BATTERY PROTECTION ++++++++++++++
int DisableMotorUnder = 0; 0= do not disable the E-Turbo under a certain voltage 1= disable under a certain voltage.
int Use12vSensor = 1; 0= Use the High voltage for disabling "ETurboVolt" .1= use the 12v battery ( for 12v e-turbos ) for disabling
int DisableMotorUnderVolt = 1200; 1200= 12.00v
float DisableMotorTime = 120000; 60,000= 1 minute disable more for...
++++++++++++++ EXTERNAL CONTROL SWITCHING ++++++++++++++
***There is a out put pin on "PIN_PowerOn" that will turn on when 12v voltage above "ChargeOverVolt" used to turn things on when the car is running. This can be used to power a Mosfet OR LOW power Relay
PIN_PowerOn
int MotorRunningSwitch = 0; 0=Off, 1=only when boosting (over Idle), 2= Idling and Boosting (over 0 % speed). this can be used to run loud cooling fans only when needed (When the motor is running).This can be used to power a Mosfet OR LOW power Relay
float MotorRunningSwitchContinueFor = 30000; 60000 = 1 minute. once the motor is off it will continue to run (cool) for a period of time.
PIN_MotorRunning
These are the Resistor values for a Voltage Divider for the cars 12V voltage system (15v)
The Ardunio Nano can only handle 5v In put so a voltage divider must be used to reduce the voltage to between 0-5v Under no conceivable case should the out put of the divider be more than 5v.
once you receive the resistors it's bet to check their values and enter those instead of the theoretical values.
Note the "5v" of the Nano as a great impact on the accuracy of the calculated voltage. Use "Debug" to see what the result is.
https:ohmslawcalculator.com/voltage-divider-calculator
Suggestion for 15v
RHigh12v = 12K ohms
RLow12v = 6K Ohms
Suggestion for 30v
RHigh12v = 30K ohms
RLow12v = 6K Ohms
Suggestion for 60v
RHigh12v = 70K ohms
RLow12v = 6K Ohms
int RHigh12v = 12000;
int RLow12v = 6000;
These are the Resistor values for a Voltage Devider for the E-turbos Battery Pack
int RHighETurboVolt = 70000;
int RLowETurboVolt = 6000;
int ChargingMode = 0; 0=Charging disabled, 1= charge only when motor off, 2= Also charge during motor idling..
int ChargeOverVolt = 1300; = 1300 = 13.00V only allow charging when the 12v system is above this voltage ( Car off it will stop charging )
PIN_Charging
Used for turning something on if the 12v falls below a voltage,Like back charging the 12v battery from the E-turbo battery.(you'll need a buck for this.)
int UnderVoltage = 1299; will turn on below
PIN_UnderVoltage
