Ok - so I presume some of you saw that I've ordered a (still) bigger ESC - this is literally the 4th ESC I've bought for this e boost nonsense (6th, if you count the two I bought for the little Audi turbo - about $3,500 worth of ESCs). My current ESC, after a once-over from APD to make sure it's healthy, along with the current TP Power motor and a Speedmaster P2 head unit will become the "small" e turbo; the Vortech/Steve Neu motor/big ESC will be the "big" e turbo.
Here's a great article on compound turbo charging and it's benefits (additive boost - a weakness of our e turbos):
www.garrettmotion.com
I should still be able to get data with the LTO/Vortech/TP Power/APD UHV-20 esc in the next month or so barring no other issues (hopefully at least a drag test; but it'll definitely hit the dyno too).
Thoughts?
Turbo Tech: Compound Turbo Systems
Compound turbo systems use different size turbos and operate in series where the first turbo feeds the second turbo boosted air and the effect is compounded
Thoughts?
