I brought this topic up in another thread but to avoid getting the other thread more off topic, I'm starting a new thread.
Air-to-air and air-to-liquid intercooloers have been used for many years on superchargers and turbos. These make a lot of sense when running lots of boost. However in either case the charge air temp cannot ever be below ambient unless you use an ice chest like some drag racers do. With less than 10 psi of boost and 90 'F ambient where I live the reduction in charge air temp makes an intercooler hard to justify. However there are a few companies that are now selling kits where the coolant for a air-to-liquid intercooler is chilled by using freon from the car's A/C system. Here are a couple
But the heat exchanger for the intake air on a air-to-liquid system is not that expensive:
And a plate exchanger to cool the liquid coolant with freon is not that expensive:
And a pump to circulate the coolant is not that expensive
Then just need an expansion valve, a small expansion tank (say 2 gallons and a solenoid valve, hoses and fittings
Kincaid Performance Inc.
Run ice cold intercooler temps with our Killer Chiller heat exchanger designed to piggyback the vehicle's AC system.
killerchiller.com
Water to Air Intercoolers
We have a wide selection of water to air intercoolers.
www.frozenboost.com
20-Plate 4-1/4" x 12" Brazed Plate Heat Exchanger, 1" MPT Ports, 316L St. Steel | eBay
Inlet/Outlet sizes: 1" Male NPT (MPT) threaded, U.S. standard threads. Plate & Outlets Material: AISI 316L Stainless Steel. Plumbing Systems. Brazing Material: 99.9% pure copper. Radiant Floor Heating.
www.ebay.com
OSIAS Electric Intercooler Water Pump 317GPH 12V Air 0392022002 for Range Rover | eBay
22718756, 15076931, 125-9020, 0392022002, 0 392 022 002. 2012-2013 for Range Rover Autobiography Auxiliary Water Pump (Electric). 2013 for Range Rover Base Auxiliary Water Pump (Electric). 2010-2013 for Range Rover HSE Auxiliary Water Pump (Electric).
www.ebay.com
