I did read and watch some of what have done yet and it is mostly with RC motors at high speed dealing with RC stuff issues.
I was wondering if anyone would have used a different route with a biffer motor. I played a bit with kick scooters/ebike and larger BLDC motors. Yes it doesn't spin fast enough to run direct drive a turbine wheel but, what about having it mated to an overdrive belt and pulley?
							 cnkunray.com
Or if not enough https://cnkunray.com/products/kr5v
					cnkunray.com
Different from RC specs, those motors are tested to run continuously at the advertised power and some run them at 2-4x past their rated power.
The cheapest one could probably run burst of 7-8kw at up to 7-8000rpm. I could probably get the rotor balanced to get it past it's max RPM design.
those are also already designed for lateral load from a drive system with room for vibration and abuse.
The controllers that goes with it work with a 0-5v throttle signal and has some safety features to accept more abuse. I think about a possible pedal throttle right below the gas pedal, to match turbine flow to engine load.
What about mating one to a P2 blower using a 4:1 pulley ratio? is it a realistic project ? I did read that it comes with a 18t pulley, i would need about 72t on the motor with a special machining to make it fit but since it is larger, i should not have issues for a larger shaft size.
				KUNRAY MY1020 48V 72V 3000W 2000W Brushless Motor with Temperature Sensor for Electeic Bike Scooter Go Karts Fardrive Controller
【High Speed Motor】 MY1020 motor with 6 mm phase wires, internal temperature sensor. 3000W Motor Max Speed is 6700RPM. 【 Fardrive ND2260 】 Sine Wave Controller Programmable, voltage 48-72V, rated power: 3KW, Max DC Current 80A, phase current 260A. 【Pure Copper Coil】High conductivity, high...
				 cnkunray.com
					cnkunray.com
