I've seen as much as 260A at 47 volts. The thing is that it seems to me that I'm at the point where there are diminishing returns when putting in more power/changing the pulley ratio. Changing the motor should tell me whether that is in fact the case.What’s currently the bottleneck in your system? It simply does not want to spin any faster? How much current is the system currently drawing?
Did you already try with other pully ratios?
I'm guessing the 70125 should be able to pull some more current without melting apart. Looking forward to the results!
They ARE uneconomical................. which is how we like itWow, 30% more air and fuel, that must be why people say they are uneconomical
My Nissan does 5.3km per liter when pottering around in town at normal road speeds, on 98 petrol it is also uneconomical. On the open road it can get almost 8km per literThey ARE uneconomical................. which is how we like it![]()
My RX8 actually gets better mileage than that.....My Nissan does 5.3km per liter when pottering around in town at normal road speeds, on 98 petrol it is also uneconomical. On the open road it can get almost 8km per literI think that works out at 12mpg for our American friends around town, and 19ish on the highway. or 19 liters per 100km town - 12.5 liters per 100km highway
I used 1 liter per lap on the track at Pukekohe when it was still open, 34.4 liters per 100km, 6.8mpg but that's foot to the floor all the time basically. My Maserati is almost free to drive by comparison![]()
Rotaries have no fear of RPMNew 25T pulley installed and tested. Results below are best I've seen so far.
Saw as much as 346A at 44V on the BMS
Getting batteries warm definitely has a positive effect on power output. Even with LTOs, which supposedly work down to very low temps.
I don't know why there is so much fuss about crank power, it's always a 'best guess' and probably over inflated but it seems in the UK and US they talk about it a lot, many of the charts seen claim engine power some howYes ...WHP . Add another 50 or so for crank.
