Hello to all forum members!
I plan to build cheapest possible 500Hp electric turbo for my street V8 (and possibly move it to other engines since it is so vehicle-independent).
But Speedmaster P-2 charger would cost about $1100 in Europe so I don't want to spend that. I want to use compressor wheel + housing from conventional turbo (cheap ebay ones). Like this:
and somehow direct drive it by a motor.
This will make system much more flexible (able to swap wheel/housings).
I have couple of questions:
1) am I right in selecting the largest wheel possibly? Reasoning is, they usually spin slower, so might be useful at some 30.000 rpm already. I think Alex even with 40KW motor could not spin compressor faster than 32.000rpm.
On the other hand, I might get Castle 1721 2400KV motor (with 33.6V LiPos) which spins to 70-80K in hope that it will spin some SMALL turbo wheel at that speed. But it's only 10-12KW AT MOST
2) Why do we use high voltage and LiPo batteries? Why not use car 13V system? Battery provides current up to 500-700A so that should be enough, and if not - put second car battery.
3) does compressor wheel put some meaningful axial load on the shaft? If so, it would require some additional thrust bearings and complicate the system
4) Not looked into it but I remember gamers use all kinds of liquid cooling their systems, might cannibalize something from that area too to increase power
Guys, please advise
Guys, please advise
